Will the 8" factory wheels fit on my 18 Charger Scat Pack ? I have found a set of factory take off 20x8 hyper silver wheels that I like better than my regular black painted Scat Pack wheels. I have the regular 4 piston brakes on my Scat Pack.
First, look at the offset stamped on the back of the 18" wheel. I think our 20's are +15MM?, so that will be your first hurdle. Secondly, see what kind of gap there is between the outside edge of the front caliper, and the inner surface of the wheel. Roughly speaking, if it's over an inch, you may be ok. While looking now at night, l see a solid 1.5" (times 2 equals probably enough for an 18"). Remember that you'll need a tall 18" tire (28.5"), to match our stock diameter, or the speedo will be off.
In the rear definitely. Here is the gap between the rear brembo and the factory 9 inch wide wheel
118611
