What is the smallest diameter rim I can fit on my 2019 Charger Daytona with 4 piston Brembo brakes for winter time?
Discussion Starter · #2 ·
I would like to put a set of 18-inch rims on here so I have a taller side wall, just don't know if they will clear the brakes. Any help would be appreciated.
Stock 18's (nor factory 20x8's) will clear your brembos without spacers. You'd need aftermarket 18's with the correct backspacing to clear the brakes if that's what you want.
What about the steel wheels? A little narrow for sure. Secondly, Tire Rack will tell you All you need to know about what will fit and not.
