1 - 16 of 16 Posts
You likely don't have the same clearances nor do you have the piston squirters; why do you think a Hellcat pump is what you need? Or is this "I read it on Facebook so it must be true"?
First I've heard of clearance being an issue? And I didn't know the hellcat had squirter like a harley. The whole reasoning is I do not wanna haveta go back into the engine because of the stock pump.
Would not know anything about the Hellcat pump except that it was designed for Hellcats. Arrington put the Melling pump in my 1st stroker back in 2016. I have used the same pump in the last two stokers with no problems.
There is higher pressure and higher volume. A stock pump will not be less than you need but if you are going in there why not.
The higher pressure Melling a spring rate change, period, the higher volume Hellcat is wider impellers.
If you put the impellers on a table with the flat sides or bores facing up the hellcat's would be a little taller. I would not doubt if it had a spring rate also just for pressure but the Hellcat engine generates massive heat and much about that engine is cooling. @WOT the injectors are held open just to name one.
The Hellcat pump is actually lest costly 68195993AC rockauto $134.79.
The MELLING 10452 same place is $168.49.
Take your pick.
Reactions: MtnRT
Discussion Starter · #8 ·
The whole point of doing this? Is the car has idle time in the winter. I bought it last fall. 200k miles. Engine was quiet. I could hear it getting noisier and noisier as winter progressed. I don't want to have to do this every other year.
What kind of build?
No sense in arguing, his mind is made up.
Points to consider:
Hellcat lifters are only so when installed in a hellcat engine, otherwise they are MOPAR Non-MDS lifters used everywhere else.
Do not mix MDS Cams & Lifters.
Buy MOPAR lifters, especially not EngineTech lifters.
Do not use Felpro (pop-off) valve stem seals, ComCams 531-16 are good.
New valve springs 6868 0909 AB
Comp Cams sells a set of push rods a touch longer to help avoid valve train noise.
While your heads are off and you can clearly see & access motor mounts and heater and reservoir hoses, change them.
Good luck. Post build progress & pics here.
Bearing clearances lol....the 5.7 is not a purpose built performance engine. The 6.1, 6.4 and 6.2 Hellcat were/are, all including piston oil squirters.
1 - 16 of 16 Posts
