1 - 12 of 12 Posts
#speedlogix
Speedlogix is happy to carry ZEX Nitrous Kits specific for the 5.7L and 6.1L Hemi!
Here is some information on what is included in these kits:
The 2005 and newer 300/Charger/Magnum Nitrous System has a fuel tap adapter that replaces the factory fuel line assembly on the passenger side of the engine. Much like the Hemi truck engine, the Charger and Magnum Hemi engines also uses a high pressure, 58psi, fuel system. Because of this, special jets are included in the kit for the optimum tuning.
  • Kit is fully adjustable from 75-125 horsepower
  • Fuel line adapter for the nitrous kit replaces passenger-side O.E.M. fuel line assembly
  • Kit fits the SRT8 models perfectly, make an easy 500+ hp with the 6.1L engine
You will be able to run a 75 Shot safely with no tuning required! In the box you also get shots for 100, and 125. To run these shots you will need custom tuning.
Price: $679.88
Here is the kit in our store: http://www.speedlogixstore.com/product_p/82177.htm
The only thing you will need to add to this kit would be spark plugs, we can help you with those as well!
ZEX has also brought the BLACKOUT kits to the market! These kits are for those that want that stealth look of an install without the standard purple.
Some more info on the BLACKOUT Kits:
ZEX™ Blackout Nitrous Systems™ are unprecedented for looks, performance and power potential. Like all ZEX™ nitrous systems, the Blackout Kits incorporate the most technically advanced performance features available, including the patented ZEX™ Active Fuel Control™. This feature automatically adjusts the nitrous fuel enrichment so your engine never runs too rich or too lean. In addition, the ZEX™ Blackout Nitrous Systems™ feature a throttle-by-wire compatible electronic TPS switch for system activation at wide open throttle. Power settings vary for each application specific kit and all ship complete with appropriate tuning jets, as well as fuel tap fittings, solenoids, filters & all necessary activation electronics.
• Black powder-coated bottle, plates & fittings; carbon-fiber look hoses
• Major e.t. reductions with additional nitrous hp; several applications available
• Kits contain patented ZEX™ features, including Active Fuel Control™ and a throttle-by-wire compatible electronic TPS switch
These kits retail for: $729.88
Here is the link to our store: http://www.speedlogixstore.com/product_p/82177b.htm
If you have any questions feel free to post here, PM us or give us a call at 1-877-BMC-RWHP!
Thanks!
This is one awesome set up..
Lots of power... Looks goods, Etc..
I love it..
I highly recommend it..
and I highly recommend even MORE that you let BMC hook you up..
They give Perfect Customer Service a whole new meaning..
SX=Modern Mopar Experts!
Do you have the NEED FOR SPEED? If you do this is one of the easiest and cost effective ways to add some hp and lower your track times. This is by far the most popular plug and play kit for the Hemi cars and we have track proven results!
This kit will get your 5.7 or 6.1L 300c nto the 11's in the 1/4 mile...and with the right supporting mods into the 10's!
We can also put together a complete package of supporting mods based on your goals, let us know how we can help!
Here is a pic of the HEMI Blackout kit ...
ZEX is a great way to add some power to your HEMI!!
We've got you nitrous addicts covered with these ZEX kits!:box2:
We've got your "Go baby, Go!" gas available!!!
Giggle gas is always available from Speedlogix for those looking to stomp out the competition!!
Got nitrous? We do!! :)
ZEX purple or Blackout kits. Take your pick!!
Add some juice to your Hemi! Quickest and easiest way to add some power and lower those track times is a nitrous system!
We're proud to be a ZEX Nitrous retailer and we offer both their standard purple as well as their 'Blackout' kits for your Charger!
1 - 12 of 12 Posts
