Cel help
151 views 3 replies 3 participants last post by  Jdlirgg
These are my codes, im thinking it's possibly more than 1 issue. Bought car used it was obviously wrecked and repaired. Had either a valve leak or blown head gasket when I purchased it. I replaced the cylinder head but reused the cams/rockers/lifters and phasers.
Im thinking the camshaft issue is the phaser. I replaced the sensors because it was cheap and easy.
Im pretty handy and trying to avoid taking it in if I can do it myself. I actually replaced the head myself.
Any thoughts or advise is appreciated. Thanks
#2 ·
Only advice I can offer is if the sensors were aftermarket replace them with factory Mopar ones.
Chargers are finicky when it comes to sensors, always best to use originals
#4 ·
2012 125,000 miles charger se 3.6
But I have bigger issues now, took the valve cover off and checked everything. While puting thr valve cover back on I pinched/shorted injector wiring harness and now I have a code for all the injectors open circuit. I'm thinking I likely fried the PCM oops 😬
