I just ordered a 2013 Charger Road & Track and was wondering if most people use premium gas and do you notice a difference than regular? All opinions welcome. Thanks!
^ thisrunning 87 octane regular...haven't seen any difference in performance or fuel economy vs. 89....owners manual states 89 recommended, 87 acceptible....running higher is just wasted money
^^^ Yes sir you stand correct. Here is why. The higher the octane number, the more compression the fuel can withstand before detonating. In broad terms, fuels with a higher octane rating are used in high-compression engines that generally have higher performance. Use of gasoline with less octane numbers may lead to the problem ofhttp://en.wikipedia.org/wiki/Octane_rating#cite_note-Ullmann-1 engine knocking. When engine knocking occurs it cause the precise timing of the spark plug and piston stroke cycle. In others words short stroking the engine. The air fuel mixture is ignited by the spark plug so if there a delay there you will not get the full output of the engine.To me premium gas is a much cleaner gas..
ALWAYS used it on my 2007 RT and I use it on my 2012 SRT. I always used it on my wife's car a Nissan Juke 1.8L engine.... Cleaner Gas means better mileage and keeps your motor running cleaner.. When you do the math you are not paying that much of a difference for better gas..
The above is probably true. However, it's my understanding that the 5.7 hemi is optimized to run on 89 octane gas. Putting 91 or 93 octane gas in without a tune will not create additional power as the stock PCM does not adjust to having higher octane.
As others have stated, the higher octane gas may be cleaner, but a good quality gasoline already has cleaners/additives in it. Bottom line, run whatever you want. I will not run 87 octane, but I see no need to run 91 octane as I cannot tune my car.
Tuning is a different story.
Technically this Octane rating is a measure of burn rate. a higher octane fuel burns slower and is *less* combustible--more resistant to premature detonatiion caused by heat and pressure.Yes sir you stand correct as well....Here is another more detailed reason why....
We all know, or some of us know that you PCM controls you electrical timing. When you purchase your cars it already set to a certain Octane level. In a 5.7L it's set to 89. Also the higher the Octane the more combustible it is. Cars with longer Cylinders such as ours require a certain Octane level to create more power. So if you put a higher octane level when it isn't necessary it doesn't effect the PCM because the PCM controls the timing and fire order so it will not cause the problem with the timing of the cyclinders. So what happens instead is excess carbon begins to build up on the piston rings which then cause them to stick. Which then cause the term blow by which is the engine burning oil and fuel which will eventually cause poor performance.
[snip]
Honestly my thoughts I don't think a 5.7L with a tune can handle anything higher then 91 Octane without switching out fuel injectors and several other parts. Now once you switch these items out then yes I think it can properly run correctly. But hey use at your own risk...
