1. DTC IS ACTIVE <A name=CHR3aa6aec89d56100489ac9cc4366981f5>1.Start the engine and allow it to reach normal operating temperature.
WARNING: When the engine is operating, do not stand in direct line with the fan. Do not put your hands near the pulleys, belts, or fan. Do not wear loose clothing. Failure to follow these instructions can result in personal injury or death.
NOTE: Diagnose and repair any system voltage DTCs before continuing with this test. 2.With the scan tool, select View DTCs.
Is the status Active for this DTC?
Yes
No
2. (K21) IAT SIGNAL CIRCUIT SHORTED TO VOLTAGE
<A name=CHRo7f7221b473d4fd2bf64491acee78a1e>
1.Turn the ignition off.2.Disconnect the Intake Air Temperature Sensor connector.3.Disconnect the Powertrain Control Module (PCM) connector.4.Turn the ignition on.5.Measure the voltage of the (K21) IAT Signal circuit in the Intake Air Temperature Sensor harness connector.
Is there any voltage present?
Yes
No
3. (K21) IAT SIGNAL OPEN OR HIGH RESISTANCE
<A name=CHRb92beab75475431188ddb712b418945e>
CAUTION: Do not probe the PCM harness connectors. Probing the PCM harness connectors will damage the PCM terminals, resulting in poor terminal to pin connection. Install Miller Special Tool #8815 to perform diagnosis.
2.Measure the resistance of the (K21) IAT Signal circuit between the Intake Air Temperature Sensor harness connector and the appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
Yes
No
4. (K900) SENSOR GROUND CIRCUIT OPEN OR HIGH RESISTANCE
<A name=CHRp5fadf8f446e48f097b7596d741a0dd3>
1.Measure the resistance of the (K900) Sensor Ground circuit between the Intake Air Temperature Sensor harness connector and the appropriate terminal of special tool #8815.
Yes
No
5. INTAKE AIR TEMPERATURE SENSOR
<A name=CHRh1ed04a82a68482f9ce9da8f4956758e>
1.Turn the ignition off.2.Connect the Powertrain Control Module (PCM) connector.3.Connect a jumper wire between the (K21) IAT Signal circuit and the (K900) Sensor Ground in the Intake Air Temperature Sensor harness connector.4.Turn the ignition on.5.With the scan tool, read the Intake Air Temperature Sensor signal voltage.
NOTE: The sensor voltage should be approximately 0.0 volts (plus or minus .1 volt) with the jumper wire in place.
Does the scan tool display the voltage as described above?
Yes
No
6. POWERTRAIN CONTROL MODULE (PCM) <A name=CHR3aa6aec89d56100489f29cc4366981f5>1.Using the wiring diagram/schematic as a guide, inspect the wiring and connectors between the Intake Air Temperature Sensor and the Powertrain Control Module (PCM).2.Look for any chafed, pierced, pinched, or partially broken wires.3.Look for broken, bent, pushed out or corroded terminals.4.Monitor the scan tool data relative to this circuit and wiggle test the wiring and connectors.5.Look for the data to change or for the DTC to reset during the wiggle test.6.Refer to any Technical Service Bulletins that may apply.
Were any problems found?
Yes
No
- Replace and program the Powertrain Control Module (PCM) in accordance with the Service Information.
- Perform the PCM Verification Test.(Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure)
- Do not worry about the special tool just be careful not to spread the pins in the commectors. Use straight pins for probes. I suspect the sensor is bad from what I read here. Use a DVOM to measure the voltage and resistance values.
