Does anyone know why I need to change my spark plugs in my 2012 charger R/T every 30,000?? Can the original plugs go longer??
One day, I might build up the courage. I work long hours and as much as I enjoy working on cars, I just don't have time to do it, for now I will have to resort to writing checks for things of this nature. Thanks for the encouragement!It's really not bad. I watched a video on Speedysgarage.net. He has a challenger with the same engine setup. I followed all of his tips and it was easy. I just took my time and did them 1 by 1.
Yep, they state 30k for a reason, you proved it here.see my post with pics here at 36k [url]http://www.chargerforumz.com/showthread.php?p=1652131#post1652131[/URL]
I believe the 2014 model year was the change to the 100k mile spark plug maintenance interval. Happened with Chargers, too, I think. Maybe they changed something else, too.The man reason is that they are standard copper plugs. While platinum and iridium fine wire plugs offer longer life and a more open ignition area, copper is still a better conductor. This selection may be due to the fact that the coils are driving two plugs each and the copper works better. Yep there are 16 of them. A friend of mine's 2014 Chrysler 300 Hemi has a more standard tuneup interval so there is something in our application. On the bright side they are not expensive (especially if you have to buy 16), there is plenty of room in the engine bay (try a sideways FWD V6), and I have always found changing plugs quality time with my engine.
I seen on another site from a member that posts on here that the 2014+ are running p/n SP143877AA which are the NKG iridium. I'm approaching 30k in about half a year and was anticipating changing out the stock plugs and was surprised the manual states a 100k mile interval.Out of curiosity I took a look at the part numbers of the ignition coils between the 2012 and 2014 and they are the same part number. Since the computer controls the entire profile of the spark, timing, intensity, duration, etc. it's possible that there is a different profile programmed to optimize the later style plugs. That being said it doesn't look like you will be hurting the coils if you want to try a fine wire platinum or iridium plug.
Same here. And the ignition coils won't determine which spark plug is used... the spark plug part number would do that...I seen on another site from a member that posts on here that the 2014+ are running p/n SP143877AA which are the NKG iridium. I'm approaching 30k in about half a year and was anticipating changing out the stock plugs and was surprised the manual states a 100k mile interval.
Unless you have a MY2014 5.7. Not sure about the 2015s.If you have a 5.7 you are using the copper plugs. Copper plugs should not be used after 30-35k, if you want longer lasting plugs, then go platinum or iriduim, buy for our cars you get the most out of the coppers
The V6's have always had a 100k mile maintenance on the plugs, if I remember right. My 3.5L '08 did, at least, and I'm pretty sure that's what the manual has always said for the V6's. Our 5.7L Hemis, for some reason, used copper core plugs at 30k mile intervals... not sure exactly why, but I wouldn't mind sitting down with someone at FCA and talk about it. Just the engineering curiosity in me, lol.I've got a 2012 Charger Blacktop edition which I purchased brand new right out of the showroom (3.6L V6 & the 8-speed auto). Here is what my owners manual states.
- OE Mopar spark plug - RER8ZWYCB4 (Gap 0.043 in [1.1 mm)
- Replace the plugs at 96,000 miles or 72 months (156,000 kms) for the 3.6L engine
I only have 25,000 miles (40,000 Km's) on her...and on a recent 500 mile round trip I averaged... (I'm from Canada so owe use an imperial gallon which is a little bigger than the US gallon)
7.7L per 100 Km's which works out to be 36.685 imp MPG or 30.547 MPG for the US gallon. :TU:
My car is pretty much bone stock, except I use 0W 30 Amsoil 'signature series' synthetic oil & a K & N air filter. My Michelin X-Ice 3 winter tires were on (34 PSI) & the heater was on. I use only shell 87 octane regular fuel with nitrogen & my average speed was 73 miles per hour (117.4 Km's per hour).
I think my spark plugs are still good for another couple of years personally. :TU:
I changed mine on the Challenger right at 30k and it looked liked they could go at least 20k more.I actually just bought a set of new NGK copper plugs from Rockauto yesterday in anticipation of doing this change in the early spring when I take it out of hibernation. Right now my 2011 is at about 34k miles...I'm curious to see the condition of the current plugs. I don't constantly beat on the car but I do like to drive in a "spirited" manner from time to time. Btw, the plugs were only about $3 a piece.
