WTF... Engine Light ??????
2.6K views 15 replies 12 participants last post by  liljoejoe54
:4-dontknow::4-dontknow::4-dontknow::4-dontknow:
I was driving last night light traffic doing about 35 mph.
Traffic opened up so I press on the gas. The car took in a deep breath, Stalled and then turn off.. I turned it back on with no problem..
This morning my engine light was on for my whole trip to work. 40 min..
When I got to work. I turned off waited a few min's then turned it back on..
Engine light off... What the Hell.. :4-dontknow::4-dontknow::4-dontknow:
I'm about to get street heads and cams in April.. Is this something I should worry about. Will the dealer charge me to look at the car if the engine light is on while I'm still under warranty ?? Because after I install cams and heads. I will no longer have a warranty..
#2 ·
I would think so, brother. I have read on these forumz that some dealers will honor the warranty after such work, but I would bet money that the majority would not. Maybe you need the Predator right now. I know that you have CAI and aftermarket exhaust. Maybe the A/F mixture is a bit off with the stock PCM flash. Oh wait, you did buy some sort of tuner didn't you?
#3 ·
Better get that car looked at Bullish, because it is likely you can kiss your warranty goodbye. You might get lucky like peno said though
#4 ·
I had something similar happen to me.. although I wasn't going 35 and gun it. I had my car go into limp mode when driving for no reason... Got out my superchip, and read a code that said it was a misfire. I reset it, and never had a problem since... knock on wood.
#7 ·
Now remember I'm a Dumb Dumb when it comes to car..
What is EGR.
I do not remember if it had a rough idle.. I was to busy having a heart attack..
It recirculates your exhaust gases. It was brought in, if I recall in the early Seventies, by the Pollution Nazi's.:TD:
Have it checked out. I have had my endine light come on a couple of times this winter after going on the highway soon after start up. However my car never stalled...it ran fine. I know the code on mine was regarding the 02 sensor and probably because I have the 180 stat, CAI and Catback. All I have doen is pull fuse 11 and all is fine.
Good luck with it.
#8 ·
This happened to me a while back I was crusing along and slapped it into neutral to do a engine rev and it lost power and the light came on for the day then went off. Never had a chance to check it out. Never happened again. Good luck
#10 ·
Touch wood, but the engine light on our Charger has never come on...:)
However our Ram...well that's a different story...:mad:...last winter it was almost a daily occurance until they finally flashed it and changed some sensors out after the flash.
#11 ·
i think there is so much computer crap in these cars sometimes they glitch. like how your home computers do weird crap sometimes.
once in a rare while my car says my driver door is closed when its open, and twice Ive had the "check tpms system" flash on the dash but the pressures it says afterwords are perfect. so I ignored it. Ive never had the car turn off or the check engine light tho.
#12 ·
I agree...I think sometimes they need to be rebooted to get straightened out.
#16 ·
The code might still be in there. To see the code, turn your car completely off then turn the key to "ON" but don't start it, then back to off like 3 times and you will see the code where the mileage is. Post the code of do a search on it. This might help you find out why it turned off.
